Displays a table of the current Link-State Database (LSDB).
| detail | Specifies to display all fields of matching LSAs in a multi-line format. |
| stats | Specifies to display the number of matching LSAs, but not any of their contents. |
| area-identifier | Specifies an OSPF area. |
| all | Specifies all OSPF areas. |
| lstype | Specifies an LS type. |
| lsid | Specifies an LS ID. |
| lsid-mask | Specifies an LS ID mask. |
| routerid-address | Specifies a LSA router ID address. |
| interface | Specifies to display interface types. |
| vlan-name | Specifies a VLAN name. |
Display in summary format.
ExtremeXOS provides several filtering criteria for the show ospf lsdb command. You can specify multiple search criteria and only the results matching all of the criteria are displayed. This allows you to control the displayed entries in large routing tables.
A common use of this command is to omit all optional parameters, resulting in the following shortened form:
show ospf lsdbThe shortened form displays all areas and all types in a summary format.
You can filter the display using either the area ID, the remote router ID, or the link-state ID. The default setting is all with no detail. If detail is specified, each entry includes complete LSA information.
The following command displays all areas and all types in a summary format:
show ospf lsdb
This command is available on platforms with Base license, or higher, as described in the Switch Engine v33.1.1 Licensing Guide document.
